Half screen darker than other
Bear in mind this doesn't have to do with lines. It's the brightness of the screen, darker on one side than another, and this is on a new screen.
This is a new screen, and for some reason it's darker too left, but more dark on almost all the left side. I've never had this happen before. Has anyone else seen this or know why?
Is dit een goede vraag?
9 opmerkingen
do you have another screen to try?
Need to figure out if its the screen or the phone
door Josh W
I don't right now unfortunately..
door Ed Kraus
I've just replaced a screen on a 6s plus and experiencing the exact same issue. Only difference is this screen is greyed out on the right side. It's definately not the screen, because I took it off and put it on another 6s plus and it was fine. The darkness sometimes goes away completely and then comes back. I thought it must either be a software glitch or possibly static build up in the phone? Any help will be amazing. The customer thinks I messed up their phone.
door MATCHES
I have this too. It suddenly goes either darker all over even though brightness is 100% or (slightly better I guess) just dark on the lower half of the screen. Very annoying. It’s been like it for a few weeks.
door Sue Gauge
I too am having the same issue. Last year I brought into Apple initially for battery issue. After they couldnt solve it they replaced supposedly with a new one. Then the shading issue started. They tried replacing screen but it only worked for a week or two then shading again. They replaced the phone two more times and finally it was gone. However, just under a year later it started to happen again. They just replaced screen because the genius was sure the others hadn’t done that before (she didn’t believe me). She then denied this has been an I phone 6 problem but went ahead and replace screen. It has worked for a week and I am back with shading on right side of screen.
door Greg Conway
4 commentaren meer tonen
