using a islack to change battery
hey can I use a islack to do the battery on a 6s
Is dit een goede vraag?
Take it in for the repair program:
https://www.apple.com/support/iphone6s-u...
UPDATE
Here's where to check to see if it is eligible:
Was dit antwoord nuttig?
The iSclack will not have the power you need to pull the battery off. If you google how to remove the battery, there are some guides to doing it but you basically need to carefully get at the adhesive under the battery using the tabs at the bottom that have been left. By slowly pulling on these you will strip all of the adhesive from under the battery and it will simply fall out.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 131
