Ga door naar hoofdinhoud
The third iteration of Lenovo's Yoga line of notebooks, similar in design and hardware to its predecessors. Designated by model number 80HE000DUS.
19 Vragen Bekijk alle
Plastic strip on bottom of display
I have replaced the display (not for the faint of heart) and everything is working beautifully. However, I can not get the plastic strip to stick back on to cover the screws at the bottom. Do I need to buy a heat gun to melt the glue? I want it to look perfect.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
i used plastic super glue to fix mine about 2 months ago and its holding up beautifully. just used four small drops along the strip and held each one for about 45 seconds.
Was dit antwoord nuttig?
Try some double sided tape and blow dryer. Apply the tape to the rear of the plastic, and heat carefully with the blow dryer to form a tacky surface more than what the tape is now. This will also insure a tight bond of the tape to the plastic. CAUTION! DO NOT HEAT MORE THAN NECESSARY!
Voeg je antwoord toe
karengail zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 148
