Ga door naar hoofdinhoud
The Kenmore Elite HE3 is a washing machine by Kenmore.
668 Vragen Bekijk alle
It wont respond at all?
Its plugged in and the breaker has NOT tripped but when I push ANY button it does nothing. It's like its dead HELP
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Good answer +
door
We sometimes have to turn off the breaker switch in the basement that powers the washer, and then switching it back on seems to be all that is needed to "wake it up."
Voeg je antwoord toe
laura lee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,193
