Ga door naar hoofdinhoud
The 2003-2005 Pontiac Sunfire is a more streamlined updated version of the popular car.
7 Vragen Bekijk alle
My car won't run after bypass attempt
My car 2005 sunfire was running until I lost the keys. I drilled out the ignition so I could replace it instead of waiting for the new ignition to arrive I attempted the bypass scenario with failure.I forgot to disconnect neg side of battery. Its still not runningcant really keep the battery charged long enough to trouble shoot
My three wires to the ignition are WYB I USED THE yellow cut it tried the only resistor I had at the time. New ignition is in the wires are together . I tried the 3step 10 min I checked all fuses relays there good. Coil pack is firing . I need help please
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Anti theft is working well . you need a new key and tumbler and it will need to be programed in to work.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
James stevens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 246
