Ga door naar hoofdinhoud
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
Why doesn't my speedometer work?
The speedometer and odometer both stopped working at the same time in my '97 Honda Civic.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
U will find a cable it will be solid black with small amount of flex like a push bike break line now that will run into your gearbox near the furtherest end of the gear box away from the motor u should be abel to unbolt it from the gear box and it will have a little plastic gear that will be shreded once u take that out then u can go get a new one.
Was dit antwoord nuttig?
Voeg je antwoord toe
ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 436
