Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1588 Vragen Bekijk alle
iPhone glitches when twisting
I have an iPhone 5C it works perfectly but I noticed that when I apply just the lightest amount of force and twist the phone the screen starts to glitch but as soon as the pressure goes away it returns to normal. I've never noticed this in other iPhone 5C's. What would cause this to happen?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
De essentiële toolkit
De meest behulpzame tools in onze meest compacte kit.
Koop nu
Koop nu
2 Antwoorden
Gekozen oplossing
Has the screen been replaced before? Only thing I can think of is different quality screens from original. It could also be due to putting stress on the logic board components as I'm pretty sure the logic board will flex slightly if you try to twist the plastic housing of the phone.
Was dit antwoord nuttig?
Score 2
Please do not force any twisting or bending motion to the phone the reason your noticing the glitchy issue is that by twisting and bending the device you may be putting stress on the ribbon cables or the backlight on the screen that glitch is essentially a controlled short being created between the backlight and the digitizer
Score 1
Voeg je antwoord toe
CAB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 54
