Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5064 Vragen Bekijk alle
talk to text won't work
on my brothers iPhone 6 his talk to text just stopped working. when you click it it loads then stops and nothing. i had him check his settings to make sure everything is ok. i had him reset phone and that didn't work. Siri works still. he's running newest IOS too
Could this be a hardware issue?
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
1 Antwoord
hello, I have the same problem when there is a data connection problem to the phone line. if you have Wi-Fi data connection and does not work Siri may have problems if the speaker does not work, you can make normal calls and the others hear you during conversations then rule out a hardware issue. restoring've already done so without putting up but trying it as a new iPhone?
Was dit antwoord nuttig?
Voeg je antwoord toe
brett stewart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 725
