Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1759 Vragen Bekijk alle
Unresponsive screen when installed
My screen works fine when not Clipped in and screwed in, but when I push it down and clip it in it becomes unresponsive. If you keep the phone open and pull it it a tiny but it works, but pushing it in and clipping it in renders it useless. I've resat the connectors 20+ times but I don't know.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
3 Antwoorden
Gekozen oplossing
If the front display ribbon cables feel like they clip in 100% fine and you have tried cleaning both connection points with 99% isopropyl alcohol and have tried holding the power button with the battery unplugged for 10 seconds.
Then I think it's safe to say you got a faulty screen. I had a iPhone 5S screen that did this exact same thing. Is the housing of the iPhone 6 as dented in or bent in any way that makes the screen not sit flush?
Was dit antwoord nuttig?
Score 3
Commentaar:
Not to a serious degree. I mean it has drop marks and small dents but no big deal. Nothing to be in the way of the screen
door
what does holding the power button with the battery unplugged do?? I'm curious i've never heard that method.
door
Drains any residual power in the circuit (or any connected internal components) of the phone. It has fixed an issue once where the touch screen was behaving erratically on a new screen.
door
Het nuttigste antwoord
You have a problem with the flex cables on the screen.
Score 3
Commentaar:
It's a brand new screen
door
As someone else has said, you have a problem with the flex cables, they are torn inside, therefore you need to install a new screen on the device in order to fix this issue.
Score 2
Voeg je antwoord toe
monsterjamfan30 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 118
