Can't remember password on a proscan tablet
how to reset password on proscan tblet
Is dit een goede vraag?
Press power button and volume up bottom at same time for 5 sec. Release and the factory rest screen comes up. It's an excellent tutorial on YouTube. I kept trying what jay on said but it did not work on my tablet.
Was dit antwoord nuttig?
Finally, this works! I'll make a note of this one. Seems each proscan has different button setup. Many thanks. Bob
That work for me Thank u
You are very welcome.
So helpful!! Thank you!
Uhh, I tried this and now my tablet won't turn on.... might just be mine though
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
on the side of the tablet next to the USB port are two holes: one for charger (marked DC.5v)and the other for ear buds. using the reset port on the back does not result in any of the actions you describe.
The Tablet has to be completely off before you begin. And make sure you hold the reset and power at the same time til you see ythe android logo then release both. then press both again until recovery menu comes up.
That did not work I tired that all
My solution to this problem is that we could write down our password and have the paper where we will remember and it can't be found easily by others.
I have a proscan PLT 8015 it's got a reset button no volume buttons I'm holding the reset button and the power button at the same time nothing happens even if I hold it for a minute
Go to settings and press security and the press reset password
Press power and esc buttons located on the side of your proscan plt 1074 for 3-5 sec. Then press just the esc button .,,,youll then see the factory reset as one of the options to scroll down to. Scroll down oressung esc…oress power to say yes.
Then once it is powered back on ….ut will ask if u want to reboot. Answer yes by hitting the power button again
I did that still can't get in it
WHat happns when u do the first step (pressthe power and esc buttons .) .. do u get an error message or....will it allow u to complete the next steps???
Hi @ Lisa,
The user manual for your tablet is not very helpful with what settings are available and exactly where they are located in the Settings menu, so try this generic Android OS guide on how to alter the screen lock options
Who answers the question. Where do it d it
Plt7650G don't have any information on it can I still get it to work
@Daniel Rivera
Can you charge battery in the tablet OK?
If so try the Chosen Solution in this link and see if that can get it working Tablet won't turn on
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 168
Altijd: 34,024
50 opmerkingen
I have a proscan tablet plt7100g 8gb and I can't remember my password please guide me through
door pamela gaskin
i have pressed the power and reset at the same time and nothing happens
door tinman3260
The only tiny hole other than the reset button on the back is the mic. And I tried both and nothing happens. Please please please.......help me
door lytlelamb
can not remember password..would like to cance out the password and turn on and off when using
door pattyjones08242
icant open my proscan tablette no password.
=== Update (06/01/2017) ===
my tablette don,t accepte my password to open
door louise bouchard
45 commentaren meer tonen
