Ga door naar hoofdinhoud
Nvidia's new iteration of the Shield Tablet line. Released in November 2015, this tablet is optimized for gaming and runs Android OS.
20 Vragen Bekijk alle
Why my device not powering on?
1. When the charger plugged in, charging symbol doesn't appear at all.
2. I've tried different power outlet and USB cables and still no respond. My pc also not detect when plugged in with USB.
3. I also tried pressing and holding down the power button while the charger is plugged in and still the device not powering on.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi.I had this problem as well.I read around and what worked for me is holding the power button down for a long time,keep holding it down until it comes on.It eventually worked.Try doing it while plugged in also.good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I can't believe it! That worked for me! seemed like forever but was actually about three minutes. After releasing button I got battery emblem. then had to push on button again till it started. Thanks so MUCH! Paul
door
did you ever find a solution?
Voeg je antwoord toe
kora zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,219
