battery wont charge, battery is working
hi there, right now i cannot use my macbook (blackbook core2duo) the battery wont charge, when i plug the magsafe it wont light up, the battery icon shows as CONNECTED, but it says battery not charging, i remove my battery and put it into my friends macbook and it does work with it and it can be charged, but my macbook wont charge it, i really like to know whats the broken part, thanks in advance
Is dit een goede vraag?
4 opmerkingen
It is very much the same for me: a desperate problem! Charles I did run that test already before and it did not notice anything wrong. Yes I did take the connector out and noticed that it is not only a connector. Indeed it has some more tiny hardware attached. So it would be a good idea trying changing that small device... The Genious guys of apple would probably swap my mother board!
door willem
I have a simliar problem but my macbook will not operate with out being plug in. I do not think my macbook is recognizing the battery is in place.
door John Gonsalves
Same problem, changed the DC-in board but did not help at all!
door willem
another interesting fact is that my macbook does not recognize my ethernet component either! It could be that the power of that component is also connected with the battery-connector?
door willem
