Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151 Vragen Bekijk alle
I removed the 3g module from my ipad 2 3g and wifi.
How can I restore my ipad 2 wifi+3g gsm when I have removed the 3g module. It stops about midway when installing firmware and never finishes with an error (1).
Maybe there is a chance to use it as an ipad wifi only?
Is dit een goede vraag?
Score 1
1 Opmerking
can you post a photo of the 3g module you removed?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No, you will need to put it back.
Unless you replace the CPU and main flash from a wifi iPad so making it a true wifi-only model.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Maybe you can show the picture , what exactly is to be removed to make it work just Wifi ?
door
Not removed, but replaced using the same part from a wifi only iPad.
The CPU is the chip which has Apple logo and A5 writing on it. The flash memory is the identical 2 large chips. On 16G models one of the spot is left blank.
BGA soldering skills required and replacing these parts can cost more than the device's worth. So it is hopeless.
door
Yes u can use wifi only. But u must try fix logic board. U must terminate Some chip on logic board. And firmware update.
Score 1
Voeg je antwoord toe
zevaksarturs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 261
