Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
893 Vragen Bekijk alle
Wont charge past 85%
I have an iPhone 6s plus that wont charge past 85% no matter what i do. The story is this was a perfectly good working phone and i removed the battery to test it out another 6s plus that was having a bigger issue. when i put this back together I soon noticed it would not charge past 85%
List of stuff I've tried.
3x different iPhone 6s plus battery's
Different charging ports
Different cables and chargers
resets
looking at battery connector under microscope, (looks perfect to me)
When i put an already 100% charged battery in it says 100% and seems normal at first yet after just a little use it drops to 85% and wont charge past.
also tried draining the battery to 0 and charging it up again yet it stops at 85%
Any idea's or suggestions would be great!
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
I'm having the same problem with a battery I purchased from ifixit. I replaced it yesterday and drained the phone till it powered itself off. Then I charged it overnight to 100%. Today it never dropped below 99%. Finally I decided something was wrong so I rebooted. Then it said it was at 55%. Shortly after that it rebooted and continues to reboot. I pulled the phone apart again and inspected both connectors under a microscope but I don't see any damage or indication they were improperly mated. There are no exposed components near the connector I could have damaged.
Worst part is there wasn't anything wrong with the battery. I needed a new Taptic Engine but I decided if I'm already going through the trouble of opening the phone up I might as well replace the battery too.
door
i have the same problem. but mine stops at 80 percent. so i turn on low power mode then keep it charging and then it will get to 100 percent. not sure why it does that and found your article and this is my work around but was looking for reason why it does it. hope it hleps
door
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
4 Antwoorden
Gekozen oplossing
This is a faulty battery problem. Even though you replaced the battery 3 times, you have probably ordered a bad batch of batteries from eBay. Order higher quality battery. I had the same problem.
Was dit antwoord nuttig?
Score 4
Commentaar:
Yes I found a 4th non oem battery that worked, maybe I just had a batch of bad batteries, thank you for your tip
door
Yeah it's pretty annoying when this turns out to be the case. Had a bad batch on iPhone 5 and 4s.
door
Het nuttigste antwoord
Did you check the small little components near the battery connector? You might have chipped one or more off when disconnecting the battery for the first time.
Score 5
Commentaar:
Thanks for the comment, I added a picture of it under a microscope, i don't see anything missing but let me know if you do
door
iphone 6s plus.. replaced screen, replaced enclosure, replaced charging port and 3 new batteries.. cant get past 85% and just a little use and battery drains fast
door
i have same problem with my iphone 7 plus. im not a tech so i dont know how to fix this one. i have a friend who fix iphones but he cant figure it out. what shoud i do? my battery stops at 48% it also drains for around 8 to 12 hrs? I guess if its on standby
please email me if you know how to fix it. thank you soo much
c.nuenay.hrm@gmail.com
had same issue wz iphone 6s plus..tried 2 batteries,still couldnt pass 85%, tried another 1,and worked ok..
Voeg je antwoord toe
computerhutsales zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 85
Afgelopen 30 dagen: 444
Altijd: 58,620
