Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Botched Disassembled, won't power back on!
Really stressed! So my lock-button was jammed, and I was fed up of using touch assist, so I took out the screws by the charger port, and tried to disassemble the thing. Some of the black plastic internal frames snapped, and that's all I can recall breaking! Now, when I realised how complex the inside was and gave up trying, I can't completely re-seal the phone and it also won't turn on! HELP!
Is dit een goede vraag?
1 Opmerking:
Do you mean the plastic internal frames of the front display assembly?
Where did you start opening the phone from the bottom or the top?
Did you work your way up and lift the screen up to like a 45° angle with the bottom part of the screen?
Can you see if any ribbon cables snapped?
door
Voeg een opmerking toe
1 Antwoord
Are you sure that it's not turning on? It might just be that you damaged the LCD. Try plugging it in to a computer and see if the computer recognizes it or not. If it does; the device is on. If it doesn't; it is indeed not turning on.
Was dit antwoord nuttig?
Voeg je antwoord toe
iNeedHelp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 51
