Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Vragen Bekijk alle
Battery replacement - blue pulsing light and black screen
Hi - I followed the guide to replace my battery. I put everything back together and my phone wont turn on. I plug it in and get a red light, which turns to green. I try to turn it on and it eventually goes to a blue pulsing light. I have tried power + volume down, and power+volume down+ volume up, and power+volume up+volume down+ home, but I don't get anything on the screen. Wondering if I could have damaged something during the repair?
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hmm. this seems to be a common symptom of screen issues. Please check to make sure your screen cable is firmly and properly snapped in onto the motherboard, and that all of your internal stuff is seated well and put back together firmly and cleanly.
Check carefully under a bright light for very small cracks along the edges under the glass - AMOLED displays are very fragile and can easily crack under stress, especially if you tried to pry the old battery out.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
i have same problem with my samsung. I have carefully check the display under the light and i didn't find any cracks on it, is there any other thing that would be smart to check ??
door
Voeg je antwoord toe
Dawson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,263
