Ga door naar hoofdinhoud
BLU Studio 7 II is an unlocked GSM smartphone with a 7-inch, 600 x 1024 resolution LCD display, and runs Android 5.0 Lollipop. The phablet was released in August 2015 .
50 Vragen Bekijk alle
couldn't remember pattern, now I'm stuck in Version test
I haven't used this phone in months so don't remember sign in pattern, I used the information from internet that said to hold volume down and power button now I'm stuck in a place that has Version, Test Pass ,Test Fail, and goes through every system on the phone repeatedly. How can I get out of this and to a clean screen without the pattern?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I got it to work. push, hold volume up & power it'll turn on other screen, use volume select factory reset and volume UP to select it.,( if you try to use power to select it won't work)
Was dit antwoord nuttig?
Voeg je antwoord toe
kyl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 116
