Ga door naar hoofdinhoud
Outdoor Bluetooth speaker with 12 hours of playtime. IPx7 waterproof certified. Shock absorbent. 5200mAh power bank.
Purchasing a battery for braven brv-x
Where can I purchase a battery?
Any part number that may be helpful in my search?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Here's how to replace it: Braven BRV-X Battery Replacement
I can't find anything on the battery. Open it up and see if the is a part number on it.
The battery in the guide shows a number but it's covered by what looks like black tape and I can't read it.
Was dit antwoord nuttig?
Score 1
In my case I replaced the battery with 2x Rechargeable Li-Ion Battery 2600mAh 3.7V Dimension: 65(L) x 18(Dia.)mm.
Glue together and solder connecting back on
Jaycar NZ
Score 1
1 Opmerking:
there is a 3rd wire for battery pack, with a 7.4v pack
door
The best batteries are the panasonic 18650 batteries. Do a google search for them. You can usually find them for $8-10 (and higher) each with a little work. The Panasonic brand is definitely more expensive but of superior quality to all the chinese knock off batteries. Will hold a charge better and last much longer on a charge.
Look for an 18650 battery looks like aa batteries and solder em on i founf some that are 5200 mah by vericore
What CDR is recommended for the 18650 for this application? I see many brands with a wide range of mAh and a wide range of CDR.
Thanks
Voeg je antwoord toe
al scoggins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 1,201
