replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
Is dit een goede vraag?
thanks
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
Was dit antwoord nuttig?
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 140
4 opmerkingen
or another more powerful, as the model a1229
door davidegatt
Why do you think the logic board is broken?
door mayer
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
door davidegatt
door davidegatt
