Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2180 Vragen Bekijk alle
after replacing battery, will not charge,turns on only when connected
After replacing the battery the phone only comes on when connected to wall charger. Battery % at 48% does not change and lightning bolt is on.As soon as taken off the wall charger the phone turns off. Will not charge with usb cable on computer.Can not make or receive calls,no sound.Did Try holding the power and home button until apple logo but no change.Does this sound like the dock connecter/charging port needs to be replaced or could I have done something else wrong when replacing battery?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It sounds like the battery connector to me. Here is a good video about a similar problem. I'm not sure about the battery percentage though.
Was dit antwoord nuttig?
Score 1
There is a chance you could have damaged a charging IC when disconnecting the old battery. Its also possible that a charging IC was bad, which led you to believe your battery was bad. I'd bet money on one of the charging IC's being at fault.
Voeg je antwoord toe
mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 82
