Ga door naar hoofdinhoud
The fourth-generation Surface Pro tablet, released October 26th, 2015.
188 Vragen Bekijk alle
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
Is dit een goede vraag?
Score 8
1 Opmerking
answer is not even about the hinge, only addresses the easy answer
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Microsoft Surface RT Kick-stand Replacement
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
answer does not address the broken hinge!
door
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
door
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
door
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
door
not helpful--hinge broken & not the stand
Score 2
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
Voeg je antwoord toe
Grant Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 15,511
