My phone pattern locked and asking unlock pin
my phone pattern locked and asking unlock pincode
Is dit een goede vraag?
Why would you want to do a Factory Reset?
Malfunctioning device (resetting the phone to original settings may fix numerous issues)
Wipe personal data off before selling
Returning it to manufacturer or retailer and want all personal data removed
What to do before you do a Factory Reset?
Backup any important files to your PC or external storage
Make sure your contacts are synced with your Gmail account
Write down a list of apps you may want to reinstall
Step-by-Step Instructions:
From the home screen, click the MENU button
Click on SETTINGS
Select the “SD & Phone Storage” option
Click on “Factory data reset” located at the bottom
Final Warning: This next step will wipe all the data off of your device. You are also given the option to check mark whether you want to wipe all data from the SD card.
Click on “Reset Phone” to finalize the Factory Reset
Done!
another option
To do a factory data reset, follow these steps:
If your phone is on, turn it off.
Press and hold the Volume up button and the Power button at the same time until the device turns on.
Press the Volume down button to select "Recovery mode." If you need to navigate to the "Recovery mode" option, use the Volume up button to move the arrow and the Volume down button to select it.
You’ll see an image of an Android robot with a red exclamation mark and the words "No command."
While holding down the Power button, press the Volume up button and release it.
Use the volume buttons to scroll to "wipe data/factory reset" and press the Power button to select it.
Scroll down to "Yes - erase all user data" and press the Power button to select it.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 677
my Samsung galaxy GT-S5282 was pattern locked and asking unlock pincode
door ravi kanth
