Ga door naar hoofdinhoud
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
196 Vragen Bekijk alle
iPad doesn't charge after battery drain
I have this iPad that charges and works fine. But as soon as the battery percentage goes to 0. It won't charge anymore. There must be a motherboard problem. What component should I replace?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
With these details we can't exactly help or at least describe but if you go to Apple they replace the charger and inspect the product its self. I was thinking that if it has some sort of overlapping ridge on the charger that is it problem and you must go to Apple for that or else your iPad will become bro land you won't be able to access it. I'm sorry that this is probably not the answer you were hoping for but this is the closest I can get with these details.
Was dit antwoord nuttig?
Commentaar:
This would probably some what help.
door
Hi Albert, first time i got the iPad it was dead. the customer told me they had problem with the battery before. So i replaced the battery and everything looked fine. Now a few weeks later the customer is back and the iPad is dead again. So i replaced the battery again and the device booted up normal. After some experimenting I came to the conclusion that the battery won't charge anymore as soon as it gets below 0 %.... so my question is what component on the motherboard should i replace? i do have soldering skills :-) ...
door
Voeg je antwoord toe
ifixshop zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 125
