The light on the drone blinks green then turns red
After I had an accident in which my Parrot Bebop fell about 75 feet, I could not turn the drone on again. When I pressed the rear light to start the drone, first the light blinked green and then turned red.
I at first thought the problem was one motor that had been damaged. I replaced the motor in question, but the light still blinked green and turned red.
Eventually, I took the drone removing the motors, camera, and gps until there was only the motherboard connected to the battery. Now, I still get the same response. When I press the turn on button the light blinks green and then turns red.
Do you have any suggestions for repairing this Parrot Bebop?
Is dit een goede vraag?
Have you found a solution? I have the same problem and am unable to find a cure anywhere.
door DJ Hill
