Ga door naar hoofdinhoud
Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1931 Vragen Bekijk alle
How to find IMEI internally?
Hey guys, my SIM tray is not stamped and iPhone is stuck in recovery mode, so I need to recover the IMEI inside the phone. Does anyone know which part of the phone actually contains the stamped #? Thanks!
Edit:
  1. No he does not have the IMEI printed on the sim card tray
  2. He can't turn the phone on as stated above.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Een opmerking toevoegen
iPhone Batterij Fix Kits
Slechts $29.99
Buy Now
Slechts $29.99
Buy Now
2 Antwoorden
Gekozen oplossing
There are multiple ways of getting your IMEI which is explained here:
https://support.apple.com/en-au/HT204073
Was dit antwoord nuttig?
Score 3
Commentaar:
I need to find it INTERNALLY. None of those methods are useful for me.
door
Then I guess you're out of luck unless you can somehow read from the Nand flash memory chips.
door
If you cannot see the IMEI, you could use the Serial to identify the device as well. Hopefully that'll help you and your cause. ;x
Score 2
Voeg je antwoord toe
xonesp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 9
Afgelopen 30 Dagen: 42
Altijd: 1,699
