Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De smalle versie van de klassieke Xbox 360 met een harde schijf van 250GB en ingebouwde wifi. Reparatie vereist nauwkeurig wrikken en speciaal gereedschap.
Will a xbox one power supply work on xbox 360 slim
I bought a xbox 360 slim from a guy. He showed that it worked, but I bought it withought the power supply. A power supply from a xbox one looks like the same. Will a xbox one power supply work on a xbox slim. They both have the 2 large pins for the plug and look the same, but I thought I would ask before i tried it.
Is dit een goede vraag?
Score 6
1 Opmerking
Had same problem with Xbox one power brick. Looked on you tube and found that Xbox 360 power brick will work with Xbox one. The ends are completely different, had to cut off ends and use end from Xbox one on Xbox 360 power brick. Wires are a little different, had to wire the following way:
All yellows are marretted together
All black from 360 and blacks and 1 grey from Xbox one end are marretted together
Blues marretted together
Reds marretted together
Works awesome, saved money from buying new brick
door Deel
Voeg een opmerking toe
7 Antwoorden
Filteren op:
Gekozen oplossing
@emmasdad no. They are not compatible. Try it only if you do not like your Xbox:-)
Was dit antwoord nuttig?
Score 6
1 Opmerking:
Thank you for the reply
door Deel
I just tried to put the power supply from my XBox One into my XBox 360 Slim (without it plugged in and drained for safety) and it won't even fit into the 360.
Score 2
1 Opmerking:
@shermantank that is correct. They are not compatible.
door Deel
My power adapter pooped out last month for my xbox one. Just found and used my old 203 watt xbox 360 power adapter. Opened case and resoldered the wires color for color. (TOOK LITERALLY 5 MIN.)amps are 16.5, 47-63hz. Exact same as the xbox one. Guess watt? No sparks!!!! Running a kinect and external hard drive. That extra 3 watts actually makes my xbox one run better. I have noticed a decrease in lag by a long shot on a lot of games. I'm not sure if that has anything to do with it but it is working faster than ever. No overheating. I have my cable tv thru my xbox so it is on for 16+ hours a day. I'm at 5 weeks and no problems. I also saved myself 50 bucks and recycled what would have been tossed at some point.
  • All you uneducated idiots posting USELESS INFO do your *******,* research before you go misleading and misinforming people. Also your the ones that look like ########## now. Hope this saves someone else a few bucks!
***Note-only use the 203 watt origin xbox 360 brick as it matches the xbox ones needs. Please make sure to check and double check.
  • also don't be an idiot obviously make sure everything has been unplugged for at least an hour before you play with any of the power adapters to avoid shock.
Score 1
1 Opmerking:
Question of the Power supply spark or pop off it will damage the xbox 360???
door Deel
Worked for me. The PSU only outputs what your system needs as the One uses about 18 amps while the 360 used about 11 so it is more than capable of powering the 360. Just like how you buy a higher wattage PSU for your gaming computer.
3 opmerkingen:
It doesnt even fit into the xbox 360 slim. I tried it :)
door Deel
Xbox 360 slim. Xbox one
Reds. Yellow
Blacks and 1 gray. Black
White. Red
Green. Blue
Its works.
door Deel
Update ur comment to "360 slim" and u can get up votes to correct this answer to the OP (original post)
door Deel
I'm about to take off the casing. Same internal pins. May or may not work.
It ain't doing me any good rn anyway
Aleight well my xbox one power brick blew out so i looked up how to use the xbox 360 slim powerbrick on xbox one all you have to do is cut out the little black part in between the two plugs and spread thme out jus a lil bit with a flathead screwdriver so it would fit inton the one and it worked anf my sytem hasnt been overheating and the brick doesnt over heat either it works great
1 Opmerking:
My xbox just stays on the green loading screen? Do you know how to fix that?
door Deel
I had a XBOX One Power adapter and wanted to check if it could be used for my 360, as users mentioned earlier, the pin shape is different and it wouldn’t fit. Saw a video which mentioned that the pins could be cut and swapped. It took me only 5 minutes, my 360 power adapter was dead, so wanted to take a chance and it works perfectly. In summary we can use XBOX one power adaptor for XBOX 360 after cutting the wires and changing the pins.
https://www.youtube.com/watch?v=rskqK_k8...
Voeg je antwoord toe
James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 140
Altijd: 50,692
