Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5s screen problem after 9.3.2 update
Hi, I sold a 5s two months ago and now the customer is complaining today that the latest update has left the screen all fuzzy and not working properly. The screen/phone was all genuine and had never been repaired. I have told them to restore it through iTunes so rule out software issues but they feel they shouldn't have to do this and of course want a full refund
Anybody had any issues with this recently?
i haven't even seen this issue on copy screens
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Im not trying to make anyone look bad, but I have seen drops cause these same issues many times. The phone doesnt necessarily have to be cracked to have screen damage from a drop. If this truly happened after a software update, then I dont know see how it's your fault at all.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
that's what they said, I would think the same but I'm sure I will be at fault for it.
door
Hey David, sorry for your troubles. We total know how customers can be when things do not go right even months later. While I do not have a solid answer on this, I would love to share some thoughts.
1. If you truly sold a perfectly good phone, there is no reason to take a return, none.
2. I can agree with Brian because normally when a phone has lines running through the LCD, this means a few things.
- The customer may have dropped it and the connector maybe loose or they damaged the LCD permanently.
-The phone is experiencing a software issues.
-Or the battery is swollen and my be placing pressure on the screen, backlight etc...
3. If the customer wants resolution on this she is going to have to factory restore the phone 1st to rule out any software, which at this point, with the Apps on the screen darken like that it really looks like it needs one.
Side Note: We have had many customers complaining about touch issues on 5 series and down since this update in store. Factory resets have helped, however one customer did recently get Error Code 56 by doing this and had to take there phone to apple. Which is definitely something this customer can do if the phone is all original.
Hope this helps!
Voeg je antwoord toe
David F zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 499
