iPhone 5c time issue (time doesn't change)
Hey hopping someone can help, I recently got a iphone 5c that was dead, I replaced the battery and the screen and i got it working again. The problem is the time doesn't set automatically even though the setting is on and when I lock the screen the time stops counting.
Can anyone help?
UPDATE
Hey so I have noticed that the time changes when the battery is charging but stops as soon as the battery is 100%. Could this be a battery issue?
Is dit een goede vraag?
5 opmerkingen
Have you connected it to wifi?
door iMedic
yes and I have tried to do it manually
door Dmtech94
My dear friend you need to turn on locations then plug in with itune time will be reset automatically if not then restore your device time and date will be ok if you still getting same problem then put compass ic . thats it job done
door Asad Abbas
Hey so I tried what you said still didn't work although now the time works but only if I have the phone connected to my pc
door Dmtech94
my friend you need to change compass ic then micro soldring
door Asad Abbas
