Ga door naar hoofdinhoud
Cuisinart Griddler GR-4N a five-in-one kitchen appliance to be used as a contact grill, panini press, full grill, full griddle or half griddle .
16 Vragen Bekijk alle
Why is the device cooking unevenly?
The device is cooking the food unevenly. I think the heat is not being distributed evenly throughout the cooking surfaces.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If your cooking surfaces are not heating unevenly your plates may have begun to peel. If this is the case they must be removed and are are in need of replacing. Your cooking surfaces and heating coils may also be out of alignment and need to be realigned, this guide will take you through the steps to do so. Additionally, you may need to just make sure that the cooking surfaces are held in place by both of the metal clips on either side of the plate. Refer to the following guide for more information Cuisinart Griddler GR-4N Cooking Surfaces Replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kayla Londono zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,479
