Ga door naar hoofdinhoud
Released June 2014, identified by model 635.
54 Vragen Bekijk alle
My power button or my on and off switch is not working.
My power was working just fine, but now it won't. It's lose. Idk what to do.
Is dit een goede vraag?
1 Opmerking
Is the back over damaged or cracked in any way?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Actually. It's easier to just replace the back cover in terms of repairability.
Was dit antwoord nuttig?
Score 3
well if it is loose then either the button has to be replace or the frame in which the button is in needs to be replaced. Hopefully it is just the button has worn down over time and that is all you need. that is a simple and cheaper fix then having to replace the whole frame
Voeg je antwoord toe
MaKayla Powell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 637
