Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Died after fall down
I fell my phone in the floor then it become very hot then switch off died
I try to switch it on , recharge it
No way
What and where the damage happend?
Can the battery damage from one fall?
For your advice
Is dit een goede vraag?
4 opmerkingen:
Where does it get very hot? Is it at the top right of the phone? You can check this from touching the back metal housing of the phone. Sounds like a power management chip has gone bad.
door
Hallo
I did change P M and the battery but still not working
Please note my Iphone bought from Dubai and they told me that parts for Europ is diffrent .. Is that correct??
But the P B i did change also for middle east // I have spare Iphone///
For your advice
door
Hallo
I just confirmed with my brother, the heat started 1 cm under the back camera then it became tooooo much hot then it hearted him realy cus of high heat
door
My phone was bought it from middle east and now iam in Euorpe, If i fix euorpen part in middle east Iphone , it work or no as it must be middle east only ??
door
Voeg een opmerking toe
2 Antwoorden
Going on with what "Ben" said it is most likely the power controller chip and it is very hard to replace and it may have damaged other items in the phone as well so... Time for a new one....
Was dit antwoord nuttig?
Did you try to restart it by holding the home and power button for about 10 secs?
Score -1
3 opmerkingen:
How to restart it if it not working at all, there is no power
door
Pretty sure the only way to fix is getting some IC or component chips replaced. Its hard to find which component chip is at fault on the logic bard upper half.
It's 50/50 chance of fixing so it might not even be fixable if the damage is too bad.
door
My phone was bought it from middle east and now iam in Euorpe, If i fix euorpen part in middle east Iphone , it work or no as it must be middle east too???
door
Voeg je antwoord toe
Imadeddin Sukkarieh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 650
