Are you on the latest Android Version called 6.0 / Marshmallow? When you plug your phone to your computer via MicroUSB / USB 3 cable you need to drag down from the notification bar / status bar then select the tile called 'USB for charging, Touch for more options' then select 'File transfers' for the Use USB for window dialog.
This should then allow you to access the files on the PC.
f that still doesn't work then you will need to go to phone settings, scroll down to About Phone, then tap on that, then tap on build number 7 times and it will show the developer options where you need to go back to the settings list to select it. Once you get in developer options scroll down and look for Enable USB debugging. Enable that and see if that works.
Other wise you may need to go into storage under phone settings then press the menu button, usually the 3 dotted menu button on the top right of the screen and change the USB connection settings there.
Still having issues? Look at the comments right below my answer for another solution.
I had this same problem. Nothing worked for me until I copied all my gallery photos and then pasted them into the DCIM folder located in my micro SD card, which allowed me to view and transfer whichever photos I desired. The "Developer" option did not work for me.
door Charles B. Mullen
I have a Galaxy J3 not the s5. Can I still down load as you said MPT ?
door DavidB Williams
I have a SD card reader that I've had to use for years back before I had a smart phone. So I just popped the SD card out of my phone, put it in the USB enabled reader, and transferred everything that way. It's old school, since I bought the SD card reader back when I had a flip phone, but it worked easy peasy. You can find those SD card readers pretty cheap just about anywhere.
door Evelyn Floyd
it could be the broken USB cable, try a new one instead otherwise you should do a full examination on ur phone.
door EmilyJames
I finally solved this problem wirelessly. Load the ShareIt app on both PC and phone and transfer photos, apps or other files easily. Your smartphone may already have ShareIt loaded. But just see that it's an updated version with the slightly changed new icon . If not just update it.
door mohsiv
2 commentaren meer tonen
