Ga door naar hoofdinhoud
A 10 speed mixer made by KitchenAid in 2006.
27 Vragen Bekijk alle
KitchenAid Professional 600 mixer not turning on?
Every time I try to turn on my KitchenAid mixer nothing happens. I've tried unplugging and plugging it back in but nothing happens. I even checked to see if it was a faulty outlet but the outlet works fine. Help!
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The wiring of the outlet plug may be faulty and in need of replacement check out our trouble shooting page for help! KitchenAid Professional 600 Troubleshooting
Was dit antwoord nuttig?
Score 2
One easy thing we see a lot is the mixer has to be in the off position when it is plugged in, or it will not turn on. It's silly but you would be shocked how often we see this. So, turn the mixer off, unplug it and plug it back in and see if it makes a difference.
If not, you are most likely looking at a bad speed control board, though you could need a new cord or motor 95 % of the time it would be a bad control board.
You can find the service manual and parts online at kitchenaidexperts.com
Voeg je antwoord toe
Luke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 188
Altijd: 5,378
