John Deere GT245 losing power
I have a John Deere GT245 that runs for about 10 minutes, then backfires and loses power and runs at abou 70% of the normal full power. I have drained the fuel and put in fresh with sta-bil. I have replaced the plugs, ran sea foam spray thru carb but it's still doing the same thing.....any suggestions?
Update (05/04/2016)
I was double checking things and found there was gas in the oil now, could that help isolate the issue?
Is dit een goede vraag?
6 opmerkingen
tomahock31 could be a valve, carburetor or ignition issue. For further information we would need to know what engine your JD has. Could be a Kohler, Kawasaki or Briggs & Stratton.
door oldturkey03
It's a 20 HP Kawasaki
door tomahock31
You could put a compression tester on it. Simple way to get some quick information.
Backfire usually means timing is off, or excess gas in a hot cylinder when shutting off.
door Frank James
Did you replace your gas filter? If that is clogged, it limits the amount of fuel sent to the engine therefore cutting down power.
door EasyIFI
How much gas? There is always going to be residual gas seeping past the piston due to all the gas is not being burned off at each combustion cycle. So you may smell a little bit of gas in the oil. But if it looks like dirty apple cider vinegar then you have a problem.
May be running super rich. Does the mower smoke out the muffler?
EasyIFI has a point. Pull off the filter and blow through it. There is a arrow on it showing the direction of flow. A good stream of air should be felt at the other end if it is not clogged. If it is clogged you will know it.
Pull the spark plug and see if is wet after running or black from carbon build up.
door Frank James
1 commentaar meer tonen
