Ga door naar hoofdinhoud
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 Vragen Bekijk alle
How to get rid of the colour seeping across my phone screen?
It used to be a small spot in the top left corner
I had a green and blue patch at the corner of my phone screen. The colour only shows when the screen is on (the brighter the screen the more visible the colour) and the abnormale colouring did not show up in any screenshots. It looks like water so I put it in rice for a few days. When I took it out it had only gotten worst. The colour has now seeped across the screen and limits visibility. What should I do?
Is dit een goede vraag?
Score 5
3 opmerkingen
Did the phone actually get wet before the issue started?
door
It may have gotten wet from humidity but it was never in water
door
yup. broken LCD as it is evidenced by the appearance on the right hand top corner. Replace it to repair your display.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@angelblais without actually seeing your screen and only going by your description, it sounds like a broken LCD. You most likely will have to replace it. Here is the guide for that. Of course, to verify this you can post some images of what your screen looks like with your original question. For that use this guide
iFixit Afbeelding
Handleiding
Voeg afbeeldingen toe aan een bestaande vraag
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
OnePlus One Display Assembly Afbeelding
Handleiding
OnePlus One Display Assembly Replacement
Moeilijkheid:
Gemiddeld
45 minutes
Was dit antwoord nuttig?
Score 4
You may have dropped it recently and it didn't break on the outside bit leaked on the inside
Score 1
I got only blue,black , violent shade on my phone corner
Voeg je antwoord toe
Angel blais zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 131
Altijd: 23,128
