Ga door naar hoofdinhoud
no command no charge help me
I have recently bought my Lenovo A7600-H
and i'm having problems and i can't charge it with my samsung charger. But when i do charge it says 'no command' i've been so sad since then.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You may want to replace the battery and hope for the best . If you did fry it by using the wrong charger it may have been only the battery that got damaged . I would start here and if you have no joy then you may want to look into replacing parts like the motherboard . You do realize just cause it fits doesnt mean you can use it ,every power unit has a specs chart on them somewhere and you need to make sure the specs are right for your particular device . Its always best to use only the charger that came with the device
Was dit antwoord nuttig?
Score 2
Did you actually insert the Samsung charger into the device and plug the charger into the wall? If so, there's a good chance that you permanently damaged the device. See if you can obtain a logic board from the manufacturer of the device. Remember, just because a plug fits in a socket doesn't mean it's supposed to go there, and using the wrong charger can instantly fry a device.
press power button and wipe data factory then reboot
1 Opmerking:
How is this done?
door
Voeg je antwoord toe
Neko ruru zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 525
