Mag Charger cable blinks green w/o the Battery
Well, I have a problem. I've changed the Mag DC Board and the battery still wouldn't charge. The led lite on the charger cable wouldn't turn on. When I remove the battery the led lite blinks a dim green. But the MB won't turn on. Once I insert the battery it stop, the led lite shut off and the it won't charge. Any clues or ideas? I'm going to clean up the battery connector and try again, but if you do have some helpful tips. I'm all for them.
First, it's has the proper MagSafe watts, even if I put the a higher watts, the MagSafe Dc Board calibrates the watts.
Second, the charger works fine with other MB/MBP. Plus i've took the charger to the AppleStore to have it tested. Battery is new.
Third, I've replace it cause I spilled soda, and i manage to clean it up. Everything on MB works fine for the exception that it doesn't charge. that's the reason why I replaced the DC Board.
On another note under systems profile, power the battery info is there but under ac plug it say no and on charging it say no, too.
Is dit een goede vraag?
4 opmerkingen
Certain you have the proper wattage MagSafe charger?
door originalmachead
Does the computer work with a different charger? or does the charger work with a different computer?
door rab777hp
also- how's your battery health?
door rab777hp
Why did you replace the DC Board to begin with?
door Majesty
