Ga door naar hoofdinhoud
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 Vragen Bekijk alle
throddle is not working
lawnmower runs in choke but runs fast in slow positions
Is dit een goede vraag?
2 opmerkingen
@booneheads runs fast in slow positions with the choke? What model is it? what have you tried to fix it? what engine does your mower have?
door
model#405002x8 12.5 hp 40" cut.looks like a small spring is broken from somewhere around carb area
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@booneheads going by your Murray number your mower should have a Briggs and Stratton 28V707 TYPE 1113-E1 engine. You said that you found a small broken spring. Could be from one of the jets as well as the linkage. Take a look at the parts manual Briggs-&-Stratton-28v700_28v799.pdf and see if you can determine where it comes from. The other thing you can do is take a couple of pictures and post those with your question. Use this guide to show you how to do that
Was dit antwoord nuttig?
Score 2
maybe there is grime in the machine. you could take it apart and/or return it if it has a warranty.
Voeg je antwoord toe
drewery heads zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 89
