Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
351 Vragen Bekijk alle
Why does my ipad screen turn off?
Ok so i replaced the LCD on my ipad mini 2 and the screen turns on and everything works fine but it suddenly turns off (just the screen) the ipad is still on because i plug it in and it makes the charging sound and the screen comes back on the apple logo if i keep the power and home button pressed but it turns off again after a little bit, any ideas??
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
There is a chance you may have used the wrong LCD. If I can remember there are two LCD models, one for higher resolution and one for normal resolution.
While they both plug in, one of them will simply not work and just show the apple logo and keep cycling the charge sound when plugged in. I don't remember if the screen stays black when it does the charge sound cycling, but most likely it does.
Was dit antwoord nuttig?
Score 2
Commentaar:
Yeah, i used an ipad mini 3 LCD but i was told they were exactly the same, and the ipad turns on an I'm able to use it but the screen goes black suddenly
door
Voeg je antwoord toe
Omar G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 110
