Why won't my wifi stay connected?
My 3rd Gen ATV worked extremely well until I brought home it's newer version, the New Apple TV. Since then the wifi has been spotty at best, it is directly over my wireless AP upstairs.
Most days it won't recognize any wifi networks (there are about 10 available from neighbors). When it does see mine it doesn't auto-connect. If I can get I connected, it loses signal the next time it turns on from sleep.
Steps tried:
Reset network settings
Restore (had to plug into Ethernet to do update for this)
Unplug and re-plug
Any suggestions or possible fixes? I would rather not take it into Apple, but am willing to do so.
Is dit een goede vraag?
That is the most direct solution but I really don't want to punch holes in my walls and whatnot.
I'd love to come up with a fix because it is supposed to work. All my other devices work fine in the same room/spot upstairs.
door Kevin Eaton
Ok well im not sure, maybe somthing got messed up, maybe the logic board could be failing or try a usb wifi adapter to see if that works better. But knowing apple the adapter could not work unless it is a trusted and well known seller and it being apple it will cost you probably more then its worth to have it looked at then it would be to get a new one.
door Cameron
