Ga door naar hoofdinhoud
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
Brake light and turn signal
When I first start driving car left turn signal and brake light don't work. If I drive about 2 miles they start working. Is bulb starting to go out?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
That's a good place to start. Bulbs are cheap. Next thing you want to check is whether you are getting power to the socket.
Was dit antwoord nuttig?
Check the socket for corrosion. Also check the wires as far back as you can making sure that the insulation has not worn through and started shorting to the car. If the insulation looks deformed and brown (melted and burnt) by the socket then replace the socket. Start with the previous answer though.
Voeg je antwoord toe
clovispam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 724
