Ga door naar hoofdinhoud
Een gameconsole voor de televisie, geproduceerd door Sony Computer Entertainment, ook bekend als de PS4. Voor het eerst aangekondigd op 20 februari 2013 en gelanceerd op 15 november, 2013.
1696 Vragen Bekijk alle
Where is the power button "clicker" on a CUH-1200?
So I got a CUH-1200 PS4 today and the only problem with it is the power button doesn't work(eject button works fine). I took it apart and see where it goes( when I got it the power button was loose) but I don't see anything where the power button is suppose to hitting or clicking against. Can someone explain how this power button works or where is the part is at that the power button is suppose to click against?
Is dit een goede vraag?
2 opmerkingen
@tronicsfix Do you have a video of replacing this piece? & do you sell replacement pieces for it?
door
@tronicsfix how much do you pay to replace the power button because i feel comfortable to dot it on my own
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
There is a part that it clicks against. There is a button that is soldered onto the motherboard that the push button pushes against. This button is what actually tells the console to turn on.
I hope this helps.
Was dit antwoord nuttig?
Score 6
23 opmerkingen:
So am I missing it then? Cause I don't see anything there.
http://i1220.photobucket.com/albums/dd44...
door
Yes, you are just not seeing it. It's under the motherboard. If you shine a flashlight on the underside of the board right where the button slides in you will see it. I'll update my original answer with a pic of the button on the underside of the board.
door
Thanks,I wonder why it's not hitting it then? I guess I'll have to remove the motherboard and look
door
Update: It isn't there,previous owner must have removed it, nothing but a little ball solder left...
door
Thanks for the update...someone must have pushed a little too hard and broken it off. If that's the only problem with it it should be fixable.
door
18 commentaren meer tonen
I have that same problem. The plastic thing that hits the contact on the mobo must be missing something, but i can not find out what it is - or where to buy a replacement. Do somebody know?
3 opmerkingen:
I don't know of anywhere that you can buy it. You might keep your eye on Ebay.
door
You can buy it on Google it's 9.99
door
What is it called ? That plastic thing for 9.99 ?
door
Got to buy the whole board son!
Just use a paper clip and leave it alone!
2 opmerkingen:
There's no way to turn it on with a paper clip with the power button missing. With the motherboard installed it would be impossible to get the paperclip back to the button.
door
Help me bro, I think you're the guy I been looking at for 2days, I think I bought that funny screwdriver for the ps4 from you too, those silver screws go where all the arrows are??? Or the little black ones??? How do you reinsert the power button???
door
Is it possible to buy a replacement for this? Mine doesnt click, seams stuck. Maybe bypass the clicker?
1 Opmerking:
what part of the power button is suppose to be clicking the part on the motherboard? I clueless...
door
this ps4 Power button switch, Easy to obtain replacement parts .egamephone have
Does anyone knows where the traces of powerbutton are cause mine powerbutton copper pads are ripped of and can’t find a schematic to see where the traces go
Voeg je antwoord toe
Travis Cox zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 75
Altijd: 16,774
