Ga door naar hoofdinhoud
The first generation Honda CRV, produced from 1995 to 2001.
99 Vragen Bekijk alle
Why has my door and rear door remote suddenly stoped working
1999 Honda CRV - the remote door opener suddenly stopped working. Did the obvious thing of changing the battery in the remote with no success. Checked the fuses still no joy. Any one have any other ideas??
Is dit een goede vraag?
Commentaar:
seria bueno tener una altenativa de traduccion,.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
It may be that the remote button 'contacts' have worn out through use over the years.
Here is a link that shows how to clean the buttons on a TV remote control unit. The principle of operation for key fob buttons is the same, so perhaps you could check your remote key fob and see if cleaning the contacts solves your problem.
https://www.youtube.com/watch?v=DBBJlGFU...
Alternatively if cleaning doesn't work, you could try re-programming your keys with the car. You will have to do all the keys for your car as re-programming only the one key renders the others useless.
Here is a link that shows how to re-program your keyless remote.
Pause the video before it ends and then click on the Show More link below the video screen to see the programming information. Take note of what happens to any other keyless remote(s) that you have for the vehicle, once you start to reprogram your remote. You have to reprogram them all.
https://www.youtube.com/watch?v=osPj0GFL...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Rod Matthews zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 113
