Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Vragen Bekijk alle
S6 after water damage. Interested behavior, need an advise.
I have s6 after water damage, it was dropped in the water for 1 sec. Now it's working only when plugged in with AC charger.
It's fully operable if plugged in AC charger(indicator of the battery goes up to 97% percent and I'm able to power on cell phone and use all features e.g. calling camera etc)
It's not working if it's plugged in pc usb port or not samsung compatible charger(data+ and data- not circuit).
What can be a problem in that case? Should I start from replacing daughter board?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I think you should try another battery then try another charging daughter board.
You can get the battery from here:
Galaxy S6 Battery
Battery replacement guide:
Samsung Galaxy S6 Vervanging van de batterij
Galaxy S6 Battery Afbeelding
Product
Galaxy S6 Battery
$26.99
Was dit antwoord nuttig?
Score 3
Yes i agree first replace battery and also try clean board with isoropyl 99 percent and toothbrush paying special attention to bat connector, common place for corrosion. Dry for 1 day or under slight heat before booting to make sure any water or alcohol under shields evaporates fully
Voeg je antwoord toe
alex12345 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 140
