Ga door naar hoofdinhoud
Electrohome USB charging alarm clock radio with time projection. Identification model number: EAAC475.
6 Vragen Bekijk alle
Time is ahead by 8 minutes
The time is off (ahead by 8 minutes) has gotten there gradually since purchased - it was fine when I first got it about 2 years ago. I am not able to figure out how to reset it. When there is a time change (Spring & Fall), it does adjust by an hour, but still wrong by same number of minutes.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
That is normal behavior for most clocks. The time accuracy is usually +- 1sec/month, or something like that. To set the time follow the instructions described in this photo.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
tried the buttons like you're supposed to.. managed to put the clock back one hour.. can't fix it :(
door
FIXED!
Note: power off, remove 3V battery, power on, reset year/month/day/12hr(am/pm)/hour/minute, replace 3V battery
Note: The translated manual is unclear or at least NOT 100% correct, I did not find DST or time zone
Voeg je antwoord toe
Estelle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,277
