Ga door naar hoofdinhoud
De Kenwood Chef A701A is een keukenmixer van Kenwood.
Drive belt keeps coming off
I have re-assembled my Kenwood Chef (it actually might be an A901 but they are very similar) after replacing caps and resistor.
The drive belt wants to come off. It has burnt channels in the top cover!
Some forum answers have suggested that the motor is turning in the wrong direction.
Why is the belt coming off and what do I need to do to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You may need a new belt . If the belt has heated and burnt on an edge it can cause the belt to go out of round . remove the belt and hang it from your finger . Does the belt hang straight or does it bend to one side if so it needs to be replaced . If this isnt the problem check the alignment of the pullies. make sure they align straight . if this is fine then make sure the belt is tight enough. Hope this helps
Was dit antwoord nuttig?
Score 2
The tension on the belt is adjusted using the three screws/nylon motor mounting bushes which secure the motor to the casing. The belt should be slightly loose - i.e. you should be able to squeeze it slightly with your fingers where it comes away from the small pulley on top of the motor. Be careful not to over-tighten the motor screws as it is possible to strip the threads in the top of the casing.
Most importantly, there should be a white plastic washer which fits tightly on the top of the small motor pulley once the belt is on. This stops the belt riding off and damaging the top cover.
Score 2
Voeg je antwoord toe
Ross Musumeci zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 1,740
