Can I use epoxy glue to keep ipad screen in place?
i want to take out the battery of my ipad air and put a new one in, but i was wondering if i could use epoxy glue to keep the screen in place.
its "adhaero" epoxy glue
Is dit een goede vraag?
No Epoxy is way to Strong If You ever Had to Remove the Screen You'd Pretty much be out of luck
HERE is Your Best Bet
Was dit antwoord nuttig?
I wouldn't with the adhesive strips. They never really work and the screen digitizer can lift after a while. The best thing to use is loca adhesive sheets. There used for sticking the digitizer to the lcd on phones but can be cut into strips and used on the frame of the iPad. It's the best adhesive I've found. It does not lift and it's easy to remove for future repairs.
B7000 glue, and get some mini plastic clamps to hold it in place for about an hour to set. No screen lifting, and comes up easy with a little heat if you ever need to open it again
I have 2 cracked screen ipads to repair, i will buy new screens (LCD's are not damaged) is B-7000 the correct glue to bond the glass screen onto the LDC Digitizer?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 884
