After HD changed, fuse (wall) tripped, no internal video, but external
Hi everybody here,
I just read a lot about diagnostics LEDs here and will give them a try when I have access to my iMac in trouble, again. Maybe, someone can help me out, quickly.
After replacement of the HD and powering the iMac on, the fuse of the electric circuit of our basement was tripped. After inserting the fuse again, the iMac started up without any signal on the display (black, no fragments viewable using a flashlight).
The iMac works properly with an external display. However, System Preferences -> Displays does only show one display - the external one.
I tried another display/video cable-combination of another iMac (same model). This does not work either with the problematic iMac. But the display/video cable-combination of the iMac in trouble works perfectly when it's installed in the other iMac.
The LVDS-connector on the logic board seems to be OK. I haven't tried to use another inverter board or power supply, yet.
I found someone who would solder a new LVDS connector, but it's quite expensive. Shall I give it a try? What do you think?
Best regards
Is dit een goede vraag?
What does it mean, if LED 4 stays off?
door Olaf
