Ga door naar hoofdinhoud
The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
Wifi , portable Wi-Fi hotspot and blutooth not switching On
When I try switching on Wi-fi it shows "Turning Wi-Fi on " but it doesn't turn on. Same is the case when I try opening Bluetooth or switching on Portable Wi-Fi hotspot.
I have tried clearing cache partition and even did a factory data reset.
I even turned on to safe mode and tried opening wifi but the problem persists.
The battery also drains quickly on a full charge I usually get around 6 hrs.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Do you still have warranty on this phone? Most likely not as it was released in 2014, this is a hardware issue.
Only thing I think might help is try updating the Android OS if it isn't up to date already. If I'm correct the latest version is Marshmallow.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
android version is up-to-date , it's 6.0.1 and warranty period is over.
door
Is it possible to replace the chip associated with Wi-Fi and Bluetooth.
door
I too have the same issue. Couldn't figure out what triggered this issue.
Voeg je antwoord toe
yatish chandra zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 168
