Ga door naar hoofdinhoud
Released 2015 Model Number: POLSP01W
Why won't my Polaroid SNAP print the pictures I am taking?
I have taken a few pictures and all of them printed out without a problem, however none of the photos I have taken recently have printed. I'm pretty sure my camera doesn't have any damage or problems!
Is dit een goede vraag?
Score 17
38 opmerkingen
Mine is printing out the paper with no pictures printed on it
door
Student-Contributed Wiki
door
Mine is printing no picture at all
door
Mine is printing out the paper but no picture on it
door
mine wont take a photo the flash goes off then stays on and the paper light blinks at me and i have to hard reset the camara does any one know whats going on
door
33 commentaren meer tonen
Voeg een opmerking toe
13 Antwoorden
Gekozen oplossing
Hi guys!
Well, I bought mine yesterday and I had the same "problem".
I don't really know why it happens but what I did was:
1. The blue paper should be a bit more "inside" of the camera than the rest of the papers. There's a little hole on the right (where it gets out from then) and when you turn on again the camera the blue paper leaves the camera immediately without doing anything in special.
2. Then you're able to use ur camera.
If you need more help, I would be pleased to share with you my experience
Bye! :D
Was dit antwoord nuttig?
Score 12
8 opmerkingen:
hey! I was having the same issue as others have stated: my camera beeps three times and then doesn't take pictures or turn off. I reset my camera so it would turn off, and thenI tried your method- putting the blue paper more "inside" the camera than the rest, and I turned the camera back on, and voila! the blue paper was ejected! I was excited, as I thought the problem was resolved, but sadly, after the paper was ejected, the same thing just happened over and over again. Three beeps, no printing, no turning off. Would you happen to have any other suggestions?
door
same thing is happening to me
door
Mine doesn’t have a blue paper
door
This answer fixed the problem for me! Thank you. I was at my wits end.
door
my camera makes the printing sound, but nothing comes out i have film in it too!
door
You probably swapped out the paper and could be using the wrong type of paper which would be the reason that the it is not printing.
Score 2
2 opmerkingen:
Also, please refer to the "Picture Will Not Print" section of the Polaroid SNAP Troubleshooting page if you are having any more difficulty.
door
I didnt put the wrong paper in I put the paper that comes with the camera. But my camera just beeps three times and doesnt take the picture and doesnt do anything
I have a big week this week and I want some pictures
Somebody help me please!
door
I took oy the blue paper and it started working
Score 1
1 Opmerking:
I took its out
door
There was a small reset button next to the charger port that you need a PIN to stick into it to reset the camera
Score 1
My daughter just had this problem. It was because the paper was upside down. When you load the paper it goes picture side up. If you are looking at the back of the camera when it prints, you should see the picture, not the writing.
Score 1
1 Opmerking:
Please help I just recently got my Polaroid snap touch and my borders and stickers do not work when I click on the icon to use them it’s blank or instead of having the borders it’s just black boxes. If anyone has had this problem please let me know if you have a way to fix I would greatly appreciate it ! :)
door
My wasn’t working because the 3rd light was blinking. This means that you have no storage left on the snap so you need to get an SD card.
Score 1
1 Opmerking:
thank u sm this helped me sm.
door
So I thought my camera was broken because I would take the photos but nothing would happen then I realised my shutter was on
Score 1
1 Opmerking:
Every time I try to take a picture on my Polaroid snap nothing comes out except for the blue card, when the blue card comes out and I try to take a picture but my camera keeps peeping two times and nothing comes out, any ideas on how to fix that?
door
I had the same issue so I have been putting this camera away for years. I just tried again, and this time I actually fixed it! Omg!! What I did was:
  1. I only put in the blue paper, and while the camera is making the printing noise, I opened the door and helped it push out the blue paper.
  2. Then I only loaded 1 photo paper, and it printed!! (I only put in 1 because I thought I’ll need to help it push again.)
  3. Then I loaded another piece of paper to see if it will work again - it did!
  4. I haven’t tried to load the entire pack of 10 papers yet. When I do, i can update here : )
Score 1
To everyone who was having this issue - I was until five minutes ago - I just took out the blue paper, even if the instructions tell you to include it.
The camera worked fine!!
3 opmerkingen:
I took my blue sheet out and now my camera won't print, and the lights won't shut off even though the camera isn't on, and the middle light keeps flashing and beeps whenever I press any of the buttons. This is brand new and I've only used it a few times.
door
the exact same thing is happening to me too!!
door
mine making the printing sound but nothing comes out. i have film in it... whats happening!!!!
door
Make sure the Zink labelled side of paper is facing down with blank side up
1 Opmerking:
Does this mean the Zink labelled side is facing the opposite side of the actual lense??
door
If you don’t let the paper roll by itself into the hole for it to print it won’t print it will come out blank, I was pushing my paper and then I just put some in there and took a picture and didn’t touch it and it printed !! Hope this helped!!!
Hi!!
My problem was solved, when I placed the Zink labelled side of paper is facing down with blank side up, that was all! the camera work and printed again!
Anita :)
Hi I have just got my Polaroid snap camera and I’m having trouble with it. When I go to take a picture it flashes as if it’s taking the picture but then freezes with the flash still on. Then if I press any other buttons while it’s doing this it does the 3 beeps. I then have to press the reset button because it won’t turn off. Please help as I haven’t been able to use it yet x
1 Opmerking:
I am having the same problem, did you ever get it fixed?
door
Voeg je antwoord toe
Aaron Hall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 123
Altijd: 99,531
